Welcher Fehler? (TTT-Technik, Tipps und Tricks)
Mc Stender, Hamburg, (vor 1643 Tagen) @ Frank K.
Vom Fehler P0607.
Gefunden hab ich da was. Für Renault.
Das wird Dir nicht gefallen.
Renault P0607 Control Module Performance
Description OBD-II Trouble Code Description for P0607 Renault Control Module Performance What does this mean? OBD2 Code P0607 Renault definition: This code basically means that the programming of the PCM/ECM (powertrain/engine control module) has failed. This can be a more serious code and may also be refered to as “ECM Internal Circuit Malfunction”. Symptoms Possible…
Ps.: Bekommt net genug "Saft" ? Stecker / Verbindungen prüfen.
