Re: Welches Motoren-Öl ? (TTT-Technik, Tipps und Tricks)
Vladimir, Prag, (vor 7503 Tagen) @ Herminator
Als Antwort auf: Welches Motoren-Öl ? von Herminator am 31. Mai 2005 10:48:
x3/34258.htm
Habe mal eine Frage bezüglich des Motorenöl´s, das Ihr verwendet, speziell für den 1.9 dTi. Mich interessiert welche Marke und was für eine Spezifikation und natürlich ob Ihr damit zufrieden seid.
Vielen Dank für Eure Erfahrungen und Tipps
Herminator
Hi Herminator,
I am certainly not an agent selling anybody’s products but I am using the following American ChevronTexaco oil to my (and hopefully the engine’s) full satisfaction. For some reason I can get it at a petrol station for roughly half the price of the oils of the same specifications (the highest possible) by other producers.
Best wishes
Vladimir
DESCRIPTION
HAVOLINE SYNTHETIC 0W-40 is a highly shear stable, multigrade passenger car engine oil of high performance. It is a full synthetic engine oil designed for LPG, gasoline and diesel passenger cars or light diesel vans equipped with or without turbocharger.
HAVOLINE SYNTHETIC 0W-40 has been formulated from all synthetic base oils and with the latest additive technology for extended drain intervals where specified by the engine manufacturer, and for year-round use of low viscosity oils.
HAVOLINE SYNTHETIC 0W-40 has been designed to perform under severe operating conditions as defined by the engine manufacturer.
BENEFITS
HAVOLINE SYNTHETIC 0W-40 provides additional advantages, in comparison with part-synthetic, non-conventional and mineral oil products, in the area of outstanding thermal stability, excellent wide range viscosity temperature characteristics and exceptional low temperature fluidity and prohibits the formation of black sludge in gasoline engines.
HAVOLINE SYNTHETIC 0W-40 guarantees an easy start, especially in extreme cold weather.
HAVOLINE SYNTHETIC 0W-40 will protect against engine failure and against engine performance deterioration, thereby reducing maintenance and repair costs.
HAVOLINE SYNTHETIC 0W-40 shows low oil consumption tendency and is particularly recommended for modern high power output engines.
APPLICATION
For gasoline engines, the ACEA A3 / API SJ performance levels, offer excellent protection against black sludge, wear and oil oxidation.
For diesel engines, the ACEA B3 performance level proves that HAVOLINE SYNTHETIC 0W-40 gives all the benefits required from a high quality passenger car diesel engine oil. HAVOLINE SYNTHETIC 0W-40 is of course perfectly suited for light diesel vans.
PRODUCT RECOMMENDATIONS AND APPROVALS
ACEA: A3-98 / B3-98
API: SJ / CF
PRODUCT MAINTENANCE
REMARK
The information given in the typical data does not constitute a specification but is an indication based on current production and can be affected by allowable production tolerances. The right to make modifications is reserved. This edition supersedes all previous editions and information contained in them.
TYPICAL DATA
Viscosity Grade 0W-40
Code number 27210
Technical version ANT
ETL – number Test methods ETL-09200
Density, 15Deg C, kg/l ASTM D4052 0.8601
Visc, Kinematic, 40Deg C, mm2/s ISO 3104 73.3
Visc, Kinematic, 100Deg C, mm2/s ISO 3104 13.10
Viscosity Index ISO 2909 182
Visc. Apparent, -35Deg C, mPa.s ASTM D5293 5090
Shear Stability 30 CEC-L-14-A-93
Visc. Aft. Shear Kin., 100Deg C, mm2/s
Viscosity Loss, %
HTHS, 150Deg C, mPa.s CEC-L-36-A-90 3.61
Pumpability, -40Deg C, mPa.s ASTM D4684 22250
Pour Point, Deg C ISO 3016 -54
Flash Point COC, Deg C ISO 2592 230
Noack volatility, %w CEC-L-40-A-93 9.5
Total Base Number, mgKOH/g ISO 3771 9.0
Sulphated Ash, %w ASTM D0874 1.02
Elemental Analysis X-RAY
Boron, ppm
Zinc, %w 0.105
Calcium, %w 0.192
Magnesium, %w 0.040
Phosphorus, %w 0.095
Nitrogen, %w ASTM D3228 0.078
Foam Seq I, IAB, ml ISO 6247 0
Foam Seq I, AFT 10' ST, ml ISO 6247 0
Foam Seq II, IAB, ml ISO 6247 0
Foam Seq II, AFT 10' ST, ml ISO 6247 0
Foam Seq III, IAB, ml ISO 6247 0
Foam Seq III, AFT 10' ST, ml ISO 6247 0
Color ISO 2049 <2.5
HANDLING PRACTICES
For information on the safe handling and use of this product, refer to the Material Safety Data Sheet (available on the Texaco PSI Intranet Site).
x3/34258.htm
